1 - 9 of 9 Posts
· Registered
I am looking to set up a 2 (4 max) cold cathode lighting system to my home stereo. I'm completely new to stereo lighting systems. I want to hook it into to my vintage Realistic STA-450 stereo receiver. I would like to know how to hook this up and what I need to buy. Please help me.
· Registered
Discussion Starter · #3 ·
You are asking, "What the heck does this have to do with audio?" Well, I have seen several people have them in their cars to flash with bass. I don't know how they hook them up. I have seen several kits online but I do not know how they work and how to connect them with my system.
· Moderator
You may want to look into DJ lighting. There's some laser and LED based lights that have microphones built in so that they can react to sound. Some of the light devices aren't expensive- $30ish.
· Registered
When I taught high-school electronics in the 1970s, one of the projects I had students build was a "color organ".
This used any audio signal to drive a small simple amplifier circuit connected to a simple filter network (very similar to the crossover network of a 3-way speaker system).
There were three outputs; Low, Midrange, and High and these in turn drove Triacs which modulated 3 sets of colored lights (7 watt Christmas tree lights).
One color was modulated by the high-frequency content of the audio, one by the midrange, and one by the bass. Any color of lights could be chosen for each output.
This was a great educational project, because it taught amplifier principles, frequency division (filtering), power control (triac operation), and they had a fun "psychedelic" gizmo to modulate lights that responded to their music (just the thing for getting stoned...lol).
They usually built a cabinet with a diffuser panel to put the lights in to create various effects from the lights.
This type of color organ circuit (not counting the lights and cabinet) can be built for around $25 in parts (it was a lot cheaper in 1975).
Amazon has several commercially packaged color organ kits available for either 12V lights or 120V AC lights. These cost around twice as much as doing it yourself from scratch.
Just go to Amazon and search for "color organ".
· Registered
Well, I thought I just did that in Post #6...lol.
I will answer specific questions, but you need to ask them first.
Originally Posted by cclayton2001  /t/1517887/setting-up-a-cold-cathode-lighting-system#post_24392349
Thanks! Not to be clingy or anything but could you walk me through all this? I'm 13 and I have a high fascination with audio and lighting.
· Registered
Discussion Starter · #9 ·
Well after I wrote that reply I started researching and so I don't know if I need that after all. The simplest way I found was to use a sound activated lighting kit for a computer, it powers straight off of a computer power supply and I was gonna use an old extra of mine. Would that work? I also was looking into color organ and I didn't know how you would connect it to the stereo itself. I also wasn't sure how to connect cold cathode lighting to it either.
1 - 9 of 9 Posts
