I want to set-up a home theatre system using Bose 901 series V speakers with the Bose equalizer as the front speakers. I still want to keep the option of listening in 2-channel mode, but the Bose manual says you can't connect other speakers to your receiver/amp and use the equalizer at the same time, as this type of setup will possibly damage the second set of speakers. The manual says you have to use a second amp to run these other speakers . I've noticed that some of the H/T receivers have a "preamp out" connection. Does anyone know if I can connect a second power amp, intergrated amp, or pre-amp to this connection to run the Bose as the front speakers while in home theatre mode. Of course, I could just unplug the equalizer. Hope this makes some sense.
