ok...i finally sucked it up and ordered digital io with hd box. it's the sa4200. even has dvi. although i probably won't use it...since i have my htpc connected to dvi for my sony hdtv.
anyways...the cable guy set my box to 480i. he said that was ideal setting. oh my! which i found odd since he seemed to be somewhat knowledgeable.
so i changed it to 720p and then to 1080i. couldn't decide what looked better. is there a preferred setting? or does it depend on tv model?
my other question. for non-hd content, is there any way to set the left/right letterbox to a black color? i don't care for the gray color.
please advise. thanks.
