Hi, I'm setting up a new 7701 for a 5.1 setup with 5 genelec 8030b and a genelec 7050 sub.
The 8030s have a few adjustments which can be made on the speaker using DIP switches, specifically a bass roof-of switch which they suggest engaging if you are using it with the sub, however I think that is primarily for when you are using these without a pre-pro and simply daisy chaining the speakers and sub together and the speakers/sub do the crossover management themselves.
There are also DIP switches for attenuating treble and bass.
Should I use any of the DIP switches to attempt to adjust frequency response in the speakers themselves, or should I just let Audyssey do the work?
My room is a 12'x16' with quite a few sound panels (GIK acoustics). both on ceiling and walls.
Advice much appreciated.
best-
-Nat
best-
-Nat
