1 - 2 of 2 Posts
Hey everyone,
I need some desperate help...My room layout isn't what you call ideal to set up surround sound. It's actually a bit smaller than the drawing, so putting the bed in the middle of the room is not really an option. Hopefully someone can help me. I have 7.1 stereo at the moment and im up for any suggestions, most likely have to go down to 5.1
...yes i know the drawing is bad...
7.1 is completely out, and even 5.1 will be seriously compromised. Using some small wall mounted surrounds, you may be able to get a passable 5.1 setup, but like you mentioned, it will be far from ideal. But experiment with speaker placement and just do the best you can.....anything is still better than the built-in speakers in the TV
1 - 2 of 2 Posts
