Status
Not open for further replies.
1 - 5 of 5 Posts
Hi
Can any of you guys that own the above tell me what the _outputs_ on the AV Centre (tuner) are? It's not obvious looking at the website.
I'm hoping to be able to take an S-Video output from the tuner into a capture card in a HTPC, use DScaler and then plug the Aquos screen into the HTPC.
Would this be possible?
KC
Super Moderator
Hi
it has the following outputs on the AV box:
RF tuner output
S video and composite video
Audio L/R
but I am not sure it will do what you want because the S video output is determined by what input is selected- you cannot make independent connections to the display
Mark
Discussion Starter · #3 ·
Mark
Thanks for the info. I'm not sure what you mean by the last sentence - not making independent connections to the display?
I switch the AVC input to the internal tv tuner, run the tuner output into a capture card, then attach the Aquos screen directly to the output on my PC's video card. If the AVC has a tuner out, then I don't understand why you don't think this will work. I'd be grateful for any clarification!
The reason I'd like to do it this way is that I suspect the Aquos tuner will be better quality than a PC tv tuner (the ones I've tried seem pretty poor).
KC
Super Moderator
OK- I see what you are doing- you are taking the tuner RF out to the PC card
would be interested to know how you make out
Mark
Discussion Starter · #5 ·
When I buy the Aquos I'll let you know!
Now scheduled for a very-soon-after-Chrismas present from me to me
:D
1 - 5 of 5 Posts
Status
