1 - 1 of 1 Posts
Another price drop!!!!! $125.00....Great Deal for Inexpensive Home theater with a very good quality projector with very few hours of operation
This projector is a quality 720P projector that I have used in my home theater for the past 5 years. It has garnered the admiration and praise for the quality of picture on a 130" Anamorphic screen. The bulb has 471 hours and it operates like new. I am being forced to downsize and I no longer have room for a home theater. My loss is your gain
Resolution 720p Native (1280 x 720)
Aspect Ratio 16:9 Native, 4:3 Compatible
Brightness 1000 ANSI Lumens
Contrast Ratio 4000:1
Display Technology DLP™ (0.62")
Compatibility
Data Signals XGA
SVGA
MAC13
MAC16
VGA
MAC19
Video Signals NTSC4.43
PAL-60
PAL-M
PAL-N
SECAM
NTSC3.58
NTSC
Connectivity
Inputs S-Video
RS-232C
D-sub HD 15-pin
HDMI
Composite Video: RCA jack
Component RCA (Y,Pb,Pr) x 2
Projection Lens
Zoom Manual Zoom
Manual focus
Image Size 300 inches diagonal (maximum screen size)
Keystone Correction Digital Keystone Correction
Operation
Power Supply 100 - 240V AC, 50/60Hz
Power Consumption 303 Watts
Lamp
Lamp Type 220W SHP
Lamp Life Expectancy Up to 3000 hours
Accessories
Remote Control Included
Physical Specs
Dimensions 12.4" x 4.3" x 11"
Weight 8.8 lbs
1 - 1 of 1 Posts
