1 - 3 of 3 Posts
Can anyone help, I have the DT-510 unglugged now and will wait till tommorrow to attempt again.
With my ps3, after a month of working, I now get a pink screen thru HDMI.
What caused problem was swapping out Receivers, but after using 3 different HDMI cables, directly to DT-510 and all 3 giving me a pink screen(I'm bypassing the Receiver altogether in these test) so I've determined it is the PJ that is causing problem. It works on another LCD that I have in the house, so its not the ps3.
What do I do to get it fixed? I'm guessing this is some sort of HDMI Handshake issue?
Discussion Starter · #2 ·
I should add, my DirecTV receiver, using the same HDMI cables works fine.
So its something to do with the ps3 and the DT510 connecting, and happened only after swapping receivers.
Try adjusting the signal type in the pj's menu.
1 - 3 of 3 Posts
