I don't have the 62U, but the similar GP1U, and let me tell you, this is NOT the monitor you want for photo editing. It has a very poor gamut that is particularly deficient in the skin tones, split pixels (Multi Pixel Technology) that can blur details, and its green as well as all three of its secondaries are way off where they should be.
By tweaking the CMS , I was able to correct the secondaries, fix green somewhat, and even out red versus blue, but the poor gamut and split pixel issue can never be fixed. Accurate calibration is essential for photo editing, especially with a monitor like this that is so far off.
If you do any significant amount of photo editing, I strongly suggest you invest in a decent quality colorimeter such as the Gretag-Macbeth i1 (only $200, I use it). It will not only help you calibrate your monitor using its own controls, but you can use the software to create ICC profiles which Photoshop can then use to help correct the remaining inaccuracies.
