1 - 2 of 2 Posts
I received this TV from parents because the sound went out. I have done some research on here and this seems like a problem after 2 years or so. They just used it to watch basic cable using component cables, the same with a DVD player. I hooked it up to their Comcast cable via a HDMI cable and no sound. My question before I take apart my current home system is: will I get sound if I connect the Sharp TV to a receiver and surround sound? I am just going to use this TV with my 360. Do you think if I hook up my 360 using the component HD cables will that work?
Any thoughts? Thanks!
1 - 2 of 2 Posts
