1 - 2 of 2 Posts
· Registered
An input problem just started on my sharp LD-23SH1U.
on any of the selected inputs the video only shows a solid pink with horizontal green lines about an inch long at random areas of the screen.
the digital input only works with my computer and not from the digital cable box.
I've tried plugging in my PS3 to both the composite and component video inputs no luck. also my old vcr does the same thing as well as the coax and antenna. only the computer via DVI works and that takes about 5 minutes to show a picture once turned on.
also no audio plays through. when the static screen does flash on for a few seconds the input & or channel selection shows properly in the top right corner.
I've tried going into service mode but with no luck.
any suggestions?
thanks for any help!
· Registered
Try searching your symptoms in the proper display forum for your set type, this section isn't for displays and you have less chance of getting an answer here. Good luck with your problem.
1 - 2 of 2 Posts
