1 - 4 of 4 Posts
I had this problem once before, but eventually got it to work. Now I can't.
The problem is that the normal lamp reset procedure on my Sharp XV-Z20000 isn't resetting the lamp timer. You have to press 4 buttons on the projector's button panel at the same time to get the lamp to reset to 0 hours. It just won't work.
Anyone else have that problem? Any solutions? I hate to take it in for service for something like that, but it's going to start giving me the lamp warning in a few hundred hours and probably will shut down at a certain point.
You can get into the service menu and do a FULL reset but that's obviously not something you'll want to try unless you have no other options as you lose all settings. I had to recalibrate my 12K mkII color wheel index so I have the service manual and would be happy to send it to you if you think it will help.
If ENTER + DOWN + RIGHT + ON does not seem to be working for you then maybe you'll want to contact Sharp.
Best of Luck,
Jason
1 - 4 of 4 Posts
