After reading this forum for a few months and acquiring most of the materials I am about to start my first project.
I have demoed a couple of subs in my room and decided to go with two subs.
Using some sonotube that I have on hand the sonosub program shows 237L and a 4" port length of 27". As each tube is 3 feet long this is what I came up with.
I am using a shiva 12" driver, mdf two layers on each end with a third layer as the cap and bottom. The calculator shows a net of 228L and a tuning of 44.8Hz. The warning is for "Driver to box top resonance is 95 hz. With a top that is three inches thick is more damping needed? What sort of damping could be used for this? Is it foam simular to the material used inside the tube?
Does this seem reasonable, is there something I should change?
nater
nater
