If you're running the crown bridged, definitely 8 ohms. If you're running just one channel of it to the dayton, either is fine as far as the amplifier is concerned.
Both will result in the same SPL?If you're running the crown bridged, definitely 8 ohms. If you're running just one channel of it to the dayton, either is fine as far as the amplifier is concerned.
Ha! I actually have 2 of these in different boxes so I won’t be running them bridged. But if I run them at 2 ohm or 8 ohm, despite the output of the amp (rated watts at impedance) I’ll get the same SPL irrespective of wiring?The amp is rated at 1300W into 8 ohms bridged or 650W into 4 ohms for two channels or 1050W into 2 ohms for two channels. So for either the bridged 8 ohm or stereo 4 ohm wiring configurations, both coils will be driven to 650W and the output stage of the amplifier will see a 4 ohm load in either configuration. So yes, it will result in the same SPL, same power to the driver and same load at the amp, for either of those wiring configurations.
But if you drive just one channel at 1050W to the coils in parallel, 2 ohms, you'll only be driving each coil with 525W, which will result in ~1 dB lower SPL, and you'll have an unused channel and therefore not maximizing the total available power. So wire in series to 8 ohms in bridged mode or at 4 ohms in stereo mode but do not wire them in parallel to just one channel. Unless you can buy another HO to take advantage of that unused channel. /forum/images/smilies/wink.gif And it probably goes without saying, but don't attempt to drive just one coil or bridge the amp into 2 ohms.
Yup, they have two models. There is one model that is the Reference HO D4.I'm confused. The reference HO as far as I can tell is single voice coil.
