1 - 10 of 10 Posts
i personally would not... i did that with a piece of electronics once, and proceeded to vacuum a piece right off a board...
i've never had a component croak because it got "too much dust" (and i'd hate to think of how much is inside some of mine
)... heck, i've had a couple survive "beer baths"... but i have killed a component by trying to clean them...
they are tougher than you think when it comes to surviving dust and grunge...
imo, ymmv, etc. i'm sure others will feel differently....
i WOULD ensure that the vents are not blocked with crud though...
Banned
I blow mine out with compressed air for my computer once and awhile. Keeps heat sinks clean and working as designed. Amazed by how much dust collects inside. I would not vacum directly inside the unit however.
lol! nah, i shoulda just sent it to tuc...
careful compressed air blasts are ok...
don't shoot it directly at the boards, etc.
Using a vacuum on any electronics is NOT good practice.
Vacuums create static electricity, and electronic components do not like static electricity.
The only exception to this is if you don't care about the risk, or you use a anti-static vacuum cleaner such as this:
http://blowerselectric.com/metro-vac...ilter-reviews/
Go into any IT department, and you'll see cases of compressed air. That's what I use on all of my electronics.
Originally Posted by bladerunner6 /forum/post/19583510
My Pioneer VSX-920-K is exposed to the air on a shelf so that it gets some ventilation.
Should I buy an electronics vacuum to keep the dust out?
After correctly reading your question:
it's practically impossible to keep dust out, unless maybe you place your rcvr in a perfect vacuum space or own a clean room such as used to make processors and hard drives.
Mr Literal.
1 - 10 of 10 Posts
