Should L/R levels after running room correction be zero?
1213 Views 5 Replies 5 Participants Last post by  T-Bone
So, after some remodeling and changes to my dedicated HT I am getting ready to redo speaker and sub calibrations.
Something that I have always wondered about is shouldn't the level offsets set by Audyssey for all the speakers be relative to the mains(L/R)?...i.e if after running room correction the mains have +/- offsets...doesnt that mean something else is off? Like sub too loud or too low?
Maybe I am misunderstanding....but I think ideally offset for L/R should be zero and the others relative to that.
That said, I have never had room correction end up with zero for L/R offsets...so like I said...probably misunderstanding.
And yes, I am bored at work =P
1 - 6 of 6 Posts
No, its to get correct relative to the reference volume. The sweeps are supposed to be at 75dB(reference -10dB) so the individual speaker volumes are set to match that for each speaker.
Volume set to 0db should show 75db on the SPL meter.
This will give you 75db with peaks up to105db when watching movies.
85dB. The sweeps are at 75dB, reference -10dB. 105 peaks is correct, 85+20.
Alter the volume control such that the center channel speaker hits exactly 75 dB with the test tone. Then all the other speakers will be adjusted by the receiver to also give you 75 dB at your seat at that volume level.
Folks have already replied. But some of the replies I don't think addressed exactly the issue you were mentioning? At least I didn't think so.
During the room correction process or general AVR setup process, the receiver emits audio of a known level. The speaker has to fire, and then the mic along with the receiver measures the level that actually got to the microphone.
The trim levels that you are referring to are only used to make sure that the audio level detected by the microphone matches the audio level emitted by the receiver. One of the main characteristics of a speaker is sensitivity.
Suppose your left speaker had a sensitivity of 88 dB, and you're right speak ahead of sensitivity of 93 dB. All else being equal, the trim offsets for the left speaker will be 5 dB higher than the trim level set for the right speaker.
The trim levels are essentially meaningless because it's relative to a particular speaker and distance of the speaker from the microphone. It's just used to make sure that every speaker has the same SPL level at the listening position.
Anyway, just trying to help.
-T
See less See more
1 - 6 of 6 Posts
