Status
Not open for further replies.
1 - 3 of 3 Posts
· Registered
Originally posted by [email protected]
two installed showstoppers... is it possible to set remote controls to operate on different frequencies so control of one doesn't affect the other...?
Different frequencies? No. Different device numbers? Yes.
You'll need to build a JP1 interface to program the remote, set up 2 devices, one for each Replay with different device numbers, then use the Multiple-replay trick so the Replays listen to the proper code.
Older Forum Discussion
Old FAQ answer
I realize you're new, in the future, please check the FAQs and search the archives for questions that have probably come up before. It would save everyone time. (especially you)
Robert
1 - 3 of 3 Posts
Status
