Well you didn't say what kind of problem you are having.
The basics are you need audio and video cabling from your ShowStopper output to your VCR input.
You need to set the VCR up to record from whatever line input you connected to. Just before you start the VCR recording, you go to your Replay Guide and Select the show you want to record to bring the menu up. On the menu you choose Save to VCR which will start counting down to when it will start to play the show. Just before it gets to 0, start your VCR recording with the idea that it should actually begin recording when the count gets to 0.
That's about it. Give it a try and if you still have problems, try to be a bit more specific about what they are. Then you can get more specific help.
Originally posted by BobS: Any advice on recording from the Showstopper to the VCR would be appreciated. |
