I have a few movies that I recorded at high quality (before I realized medium quality was best if I want to burn it to a DVD) that I would like to burn to a DVD.
I have had good success using "evtdump, rtvedit and rtvconvert" on medium quality shows, but the high quality ones are too large for a DVD.
Searching this forum, I found reference to DVDShrink and DVD2one which are suppose to reduce the size to something that will fit on a DVD.
I have run both of the products on medium quality shows, and they reduce the shows like they should. When I try to reduce the size of a high quality show, both products get started, then blow up.
DVDShrink gives me the following message:
DVD Shrink encountered an error and cannot continue
Failed to read file "G:\\"
invalid access to memory location
I know the high quality recordings sometimes exceed DVD standards. Could that be the reason for the failures? Is there some tool that will put the high quality .mpg files back into specs?
