1 - 1 of 1 Posts
I have assembled and used the Ultimate Wireless Seminar Audio System for use in seminars, workshops, intensives and events successfully and reliability.
You will be able to handle two speakers simultaneously plus a handheld for audience questions. Connect it all with a small mixer to the hotel's speakers or your own portable sound system.
Everything is in excellent condition and working order.
This Ultimate Wireless Seminar Audio System includes:
3 Shure Wireless Base Stations
2 Shure Wireless Bodypack Transmitters
1 Shure Wireless Handheld Microphone and Transmitter
For use with Bodypacks:
2 Shure Lavalieres
1 Shure Headset
1 Audio Technica Headset
Total Retail $3,238
But you can buy for it the whole system for just $1,997!
W. Vito Montone
310-571-8486
Details:
Shure Wireless System ULXS4
The Shure ULX® Standard receiver offers an exceptional value in both performance and price, for both working musicians and sound installers.
The feature set of the versatile ULXS4 receiver offers a direct path to full, clear audio signals, unencumbered and unattached.
Power On Indicator
"RF" Diversity Signal Indicators
1/4 antennas
Transmitted (TX) Audio Indicators
Receiving Antenna Indicator
Automatic Frequency Selection
Over 1400 selectable frequencies
Group/Channel Displays
Transmitter Battery Life Indicator
MODE Button for Menu Display
SET Button for Saving Settings
Mic/Line level Switch
XLR and 1/4" outputs with level control
Half-rack design
List $558.00 each
Shure Wireless Bodypack Transmitters ULX1 - J1
Three-segment battery fuel gauge.
Frequency and power lockout.
Flexible 14 wave antenna.
TA4F mini four-pin input connector.
Backlit LCD display shows group and channel setting.
List $241.00 each
Shure Wireless Handheld Microphone and Transmitter ULX2 - SM58
8-9 Hour Battery LifePower
On/Off Switch
BatteryLED-Green When ON, Red When Battery Low
Three-segment Battery Power Icon
PEAK Icon-Appears When Audio Signal Overloads
Adjustable Audio Gain Control
Input Attenuation Switch-Select 0dB for Voice/Low Output
20dB for High Output
4-pin Mini Connector
Battery Cover Unscrews to Expose Battery and Gain Control
List $316.00
Shure Lavalier PG185
Electret Condenser Microphone for Clip-on Use with a Wireless Bodypack
Clothing Clip for Secure Placement
Acoustic Windscreen Minimizes Wind Noise in Outdoor Applications
List $49.00 each
Shure Headset 519
Headworn condenser mic with an omnidirectional polar pattern
List $149.00
Audio Technica Headset BP892CW-TH TA4F
Headworn condenser mic with an omnidirectional polar pattern to give you clear, natural audio.
Audio-Technica's high-SPL BP892C MicroSet headset mic offers you high-quality, low-profile, high-performance audio. Delivering clear-and-accurate sound in an inconspicuous package, the ultra-lightweight Audio-Technica BP892 headworn condenser mic hooks securely behind either ear and can be worn for hours without fatigue. For maximum stability and comfort, the included AT8464 dual-ear microphone mount converts the MicroSet to a dual-ear-worn mic.
The Audio-Technica BP892C condenser microphone features a flat, extended frequency response and other outstanding performance specifications, resulting in extremely intelligible, natural audio for stage and television talent, lecturers, and houses of worship. Protected by a highly durable Parylene coating. Has Shure TA4F connector for use with Shure transmitters.
Features:
Handles high sound pressure levels with ease
Extremely intelligible natural audio
Inconspicuous, lightweight headset with capsule diameter of just 2.6mm
Deal for applications requiring minimum visibility
Ergonomic under-ear design: Flexible, lightweight contoured loop hooks
behind the ear for an ultra-secure, comfortable fit with or without glasses
Beige
Accessories: AT8440 cable clip; AT8157 windscreen; carrying case
List $519.00
1 - 1 of 1 Posts
