I have been experiencing some very high-pitched, but low volume, whine coming from my panel even when it is shut off. The sound emanates primarily from the bottom back right of the panel, where the power cord plugs into the unit. (Pio Kuro 5080).
Anyway, I've decided to just pull the power on the panel when not in use to alleviate my suffering. But I was curious, after prolonged use of the panel, can I just shut down then power off? Are there fans that run to cool the system after you shut down the tv? Or, does everything essentially shut down when you shut the tv down?
