I am looking for recommendation for side surround speakers that fit into a rather limited physical placement. To the sides of my four theatre chairs to right is a brick fireplace and to the left is a foyer. A bannister railing of 2x2 posts separates the foyer from the great room/theatre.
I don't think I want the side surround speakers on the foyer wall since it would be projecting partially into a hallway. I don't think I have any choice but to put the left surround between the 4x4 end post and the first 2x2 post. This would be at ear level about two feet forward of the listening position. So the speaker can't be too deep - maybe 4" at the most. There is 7 1/4" between the end 4x4 and the first 2x2.
The placement on the other side would be just to the side of the brick fireplace.
Now .. it seems to me that practically perfect for this is a "sound bar" type speaker, but they are typically designed for center speakers and usually available as part of a package of HT speakers.
Any suggestions on what would work well here?
The front speakers are Infinity 2-way RS5 floor. Center is Infinity PC350. Rear surround are Polk Audio FXi3W and subwoofer is a Mirage BPS-150. Receiver is a Denon AVR-2310CI.
