I've been trying to puzzle through what the installers of my DircTV (phase III) dish and OTA antenna (CM 4221) did by looking at the wiring in my basement.
I finally think I've figured it out. The DirecTV installer ran 3 RG 6 runs off the roof since I have 3 receivers (I should have explicitly asked for them to run all four... oh well). The antenna installer piggy-backed off one of the RG 6 runs by patching in the OTA signal using a combiner.
So, in the basement I have 3 coax runs connected to a grounding block. 2 runs then connect to the structure wiring in the house. The 3rd run (combined OTA and satellite signal) runs through a diplexer and then connects into the structure wiring.
Based on marginal signal strength on one of the OTA channels I want to amplify the OTA signal after it is separated from the satellite signal. Does this pose any problems since the RG 6 cable combines OTA & satellite upstream?
Are there any better solutions other than completely separating out the satellite and OTA signals on their own runs?
