Ok...I admit it was my mistake but I included a bi-fold door for my equipment closet under my steps. At the time it seemed like a good idea. But since I got my new sub...the damn thing rattles to all hell. It's like a piece of material is rattling between the two outside edges of the door.
You can see the door in this pic: http://www.happyapplefarm.net/Dsc00409.jpg
If I press on the door and kind of hold it "together" from both sides the rattling stops. What I was thinking of doing is putting a bolt through the middle of the panel, mounted with rubber washers and a attatched on the back with a piece of acoustic foam. Thoughts? Ideas? It's really f'n annoying.
