1 - 5 of 5 Posts
Hello, I just ordered the HDHomerun (dual tuner model) and was wondering, instead of building or buying a cheap laptop, can I buy a thin client instead to stream into the living room? Sorry if this is a dumb question. I'm a newb. Thanks!
No. While the device sits on your network, you still need to install the device drivers on every client machine. You need a computer with a supported OS so that drivers along with a software player to actually play the stream.
Boxee said they might support it down the road with their Boxee Box... to what degree I'm not sure even they know.
1 - 5 of 5 Posts
