My Onkyo TX-NR709 has several volume-related technologies available. Here's a list of them and my feeble attempt at grouping them into categories:
Category 1: Dynamic range compression
- Dolby Volume (on/off) - "automatically adjusts the difference in volume levels which can occur between different contents or source components"
- Dolby Volume Leveler (off/low/mid/high) - "maintains the perceived loudness of all contents, coming from different channels or input sources."
- Audyssey Dynamic Volume (light/medium/heavy) - "This setting affects volume the most. It quiets the loud parts, such as explosions, and boosts the quiet parts so they can be heard"
Category 2: EQ modification at low volume levels
- Dolby Volume Half Mode (off/on) - "Dolby Volume applies a bass and treble attenuation to the audio when the system gain exceeds reference level."
- Audyssey Dynamic EQ (off/on) - "enjoy great sound even when listening at low volume levels"
- THX Loudness Plus volume control technology - "enjoy even subtle nuances of audio expression at low volume"
Category 3: Source level correction
- Onkyo IntelliVolume (set in 1 dB steps) - "set the input level for each input selector individually".
Some of these modes are easier to understand than others, but overall my head is spinning. I have no idea how to best utilize them and whether it's a good idea to combine them or not. My solution for now is to turn them all off. Is there a better approach? Is there any point in using two similar modes at the same time?
