...my question is about subwoofers.
First of all, my needs are small - I'm not trying to bend any walls. And although I've HEARD of T/S parameters, we're not acquainted well enough to share a pizza yet (i.e. my design skills are nil). I've been looking at car subs for my small home theater application because I can go to the manufacturer's websites and they'll give me box building recommendations that take the guesswork out of box design. For instance, I know that as long as I keep internal volume in a well-sealed box to about .375 cu ft, that a JL Audio 8w0-8 should happily reside in the 45hz neighborhood.
Problem is, I've heard that SOME car speakers don't work well in home environments because they're optimized to take 'cabin gain' into account. Assuming I know what all that means, is there a way to similarly (and quickly, without a lot of calculations) evaluate true home theater subs and ascertain their effectiveness and ultimately box dimensions that would work?
If these particular JL Audio speakers will work well, I'm happy to use them since I have a source at a good price. But if you know of any similar 8" drivers that would be better (assuming a sealed box size of .375 cu ft or smaller), I'd be most happy to hear your recommendations.
Equipment: JVC 7.1 receiver (7x100w), Carver TS series speakers (L-C-R), Fluance dipole surrounds.
I've salvaged a 120w plate amp from an old Optimus 12" sub of mine and have my eye on a second identical amp. I am building a 'home' for my 56" DLP TV and it will be sitting between two existing columned bookshelves. These bookshelves have enough room under the bottom shelf to house an 8" sub each, and I'd like to snuggle one in there and dedicate an amp to each one.
Any help, advice, jeers, raspberries, or leftover pizza will be gratefully accepted...
