Status
Not open for further replies.
1 - 3 of 3 Posts
Discussion Starter #1
Hi,
My planned HT will use a grey painted wall with curtains.
Does anyone have a simple and pleasantly visual method of masking the 16:9 screen to 1.85 and 2.35?
Screen width would be 7ft wide maximum.
Miro.
2 closet rods and 6 yds of balck velvet. Cut 7' of the velvet in half length-wise, and secure half to the top rod (I velcro'd mine just in case I screwed up) and roll it on to the rod until the correct height is achieved. Attach the fel to the 'bottom' rod the same way, and suspend it by string - adjusting the height with cord stops (string squeeze things like on a sleeping bag). If you've got enough left over, you can use some of the velvet to make side-curtains as well, hiding the string. This si pretty much the easiers way to make them, but requires the most manual intervention for adjustments...
Discussion Starter #3
Thanks Darren.
Although it's manual, there won't be any motors and wires to hide or short out. I'll look into the rods & try to find ones which won't bend over 7-8ft.
Thanks again,
Miro.
1 - 3 of 3 Posts
Status
