Status
Not open for further replies.
1 - 2 of 2 Posts
Is there a product that will allow me to use IR to switch power on/off to an AC device? I've been through th x10 site, and it appears that I need multiple pieces that are overkill for my application.
I would like to use my Pronto IR universal remote to turn on a single florescent back-light similar to the Cinemaquest
Ideal-Lume.
The simplest/cheapest way I know is to get the following 2 items:
1. Infrared X10 Command Console ($30) http://www.smarthome.com/4040.html
2. X10 Appliance module ($5) http://www.smarthome.com/2002.html
Do not get an lamp module, they do not work with florescent lights.
You can get the IR codes from remote central for you pronto. If you need any help let me know. I am using my pronto and the above 2 items to control my florescent back-light with no problems. Good luck.
Jay
1 - 2 of 2 Posts
Status
