77" G2, 42" LG C2, Onkyo NR7100, 5.1.2 Infinity Primus + Bic PL200
Picked up a Epson HC 2000, and trying to figure out a very simple and affordable way of having a nice screen for it.
My thought was to pick up a 60x96 piece of Wilsonart laminate, and a 71x126 sheet of Carl's Place Pro Gray material. Trim it to 60in, then fold the over lap around length sides of the laminate.
http://www.lowes.com/pd_239103-466-D354-60-60X096-000_1z10we4+1z116l9+4294735648__?productId=3492063&Ns=p_product_price|0&pl=1¤tURL=%3FNs%3Dp_product_price%7C0%26page%3D2&facetInfo=White|Wilsonart
http://www.amazon.com/dp/B00DZRSFFC/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=ZZQACAM6Q1TZ&coliid=I2TI1DCMT5RMUG
Thinking spray glue, lightly applied, should work for holding it together? Then screw the sides/top/bottom directly in to the wall, and cover those edges with 2-3" black velvet tape.
Any reason why this wouldn't work? Want a perfectly flat screen with no waves (wall is flat from what I can tell, just dirty/ugly color, and I have 0 painting skills). Only concern I can think of is if I ever have to move it, would the material be ruined from the glue if rolled up still attached to the laminate? The description for the material says its stiff, and hangs nice and flat without tension. Would that mean I don't need glue at all, or possibly, dont need the solid piece behind it (the laminate) to keep waves out?
