1 - 2 of 2 Posts
Sorry for the newbie questions, I have the following:
- LCD TV with Ethernet connection and three HDMI inputs (LG 47LE5500)
- Media player (WD TV Live Plus)
- Router with four Ethernet connections (Netgear)
I just purchased these items. Haven't applied power to any of them.
What is the best setup?
Do I connect an Ethernet cable directly between the router and TV?
Do I also connect the media player to the router (using an Ethernet cable) and TV (using an HDMI cable)?
Originally Posted by Ohioan /forum/post/19531964
Do I connect an Ethernet cable directly between the router and TV? Do I also connect the media player to the router (using an Ethernet cable) and TV (using an HDMI cable)?
Yes, you need to connect each Ethernet device to the router/switch. In the future there will be HDMI devices (v1.4) that also carry Ethernet, but I don't think your devices have that feature.
Also, you only need to hook the TV to Ethernet if you want to use any of the Internet-enabled features of the set... Since you have a media streamer, depending on what services you'll use, it may be redundant. But certainly doesn't hurt.
Jeff
1 - 2 of 2 Posts
