Status
Not open for further replies.
1 - 2 of 2 Posts
I just bought a b&w 300 sub and I was wondering if I should use a y-splitter to plug into the left and right inputs on the sub, or will it be exactly the same as having only the left or right inputs plugged in?
There's no need to use both input jacks, unless you're using the output jacks, too. At the most, there might be input resistors, which using a Y-cord would parallel, but the level control would be able to set the same slight-difference in level.
1 - 2 of 2 Posts
Status
