181 - 200 of 30062 Posts
Originally Posted by mogorf  /t/1449924/simplified-rew-setup-and-use-usb-mic-hdmi-connection-including-measurement-techniques-and-how-to-interpret-graphs/180#post_22809814
Originally Posted by kbarnes701  /t/1449924/simplified-rew-setup-and-use-usb-mic-hdmi-connection-including-measurement-techniques-and-how-to-interpret-graphs/150#post_22809792
Thanks Feri, I will give that a try later and report back.
When you say 'select mic' what will it say in the Input box for the Audyssey mic?  (I assume you meant Input above??)
Sorry, you are right it should be INPUT. In the dropdown menu it will say something like "Mic1, Mic 2"...It doesn't know it's an Audyssey mic, here we are in the "good old" analog world!
Meantime, the laptop will detect that a new hardware has been plugged in!
Thanks again, Feri. I will give it a try.
Hey Guys
Long time lurker here! The short and sweet is, after starting to read this thread,decided to download REW and give it a shot. So after just playing with some of the functions yesterday without any mic or HDMI connections I got a better understanding of what I was reading about. It looked overwhelming and complicated.
So today after reading about the Audessey mic working decided to throw my ARC mic in the mix. Guess what it works.[[So far]] I even believe I have it calibrated to the program [[Yessss]] I`m not very technical with computers and they frustrate the heck out of me sometimes LOL.
Anyways question 1 is I dont have a laptop nor a comp with HDMI. So will any HDMI soundcard for my computer work [money and quality wise], second question my HDMI run will be about 25 ft will this be ok.
Thanks guys and keep it going......
** Man of Leisure **
@Heybrook,
Any current generation sound card with HDMI should work. A 25' HDMI cable should not be an issue either. If you are going to use a desktop computer, make sure that the noise (cooling fans, etc.) are not loud enough to affect the REW measurements. Also, note that the mic you are using is OK for learning and testing, but when you want to take accurate REW measurements, you will need a mic that has a calibration file for REW.
Man I hope this thread doesn't get too long by the time I get my mic. Guess I'm not helping matters. Can't wait
Originally Posted by cadett  /t/1449924/simplified-rew-setup-and-use-usb-mic-hdmi-connection-including-measurement-techniques-and-how-to-interpret-graphs/180#post_22810713
The wait will seem for ever... I'm betting at least the beginning of Feb before I get mine - depending how CPL dispatch it, it could take 10 days to get here - so you guys will have a headstart on me - which may not be a bad thing ;)  Meantime, I am going to have a practice run as per Feri's suggestion, using my Audyssey mic.
Originally Posted by JimP  /t/1449924/simplified-rew-setup-and-use-usb-mic-hdmi-connection-including-measurement-techniques-and-how-to-interpret-graphs/150#post_22809239
I'd think that the intent is to be sure that you've go the mic set for the correct sensitivity which varies depending on your computer hardware settings.
Should only take a few seconds to perform.
so any cheapo spl meter would do?
Originally Posted by Stealth3si  /t/1449924/simplified-rew-setup-and-use-usb-mic-hdmi-connection-including-measurement-techniques-and-how-to-interpret-graphs/180#post_22811026
One would think so.  However, you will find many of us use the Radio Shack SPL, so that may be a better choice.  For REW use, make sure the SPL has an output connection.  The RS SPL, for example, has an RCA connection that sends a signal to a soundcard or your laptop.
Premium Member
Originally Posted by AustinJerry  /t/1449924/simplified-rew-setup-and-use-usb-mic-hdmi-connection-including-measurement-techniques-and-how-to-interpret-graphs/180#post_22811101
On that subject--analog or digital?
Banned
Originally Posted by sdrucker  /t/1449924/simplified-rew-setup-and-use-usb-mic-hdmi-connection-including-measurement-techniques-and-how-to-interpret-graphs/180#post_22811129
If all you are using is the mic, the metering format doesn't matter.
Premium Member
Originally Posted by arnyk  /t/1449924/simplified-rew-setup-and-use-usb-mic-hdmi-connection-including-measurement-techniques-and-how-to-interpret-graphs/180#post_22811168
Thanks - I've read some comments where the analog format is still preferred by the DIYers, so good to know.
Originally Posted by mogorf  /t/1449924/simplified-rew-setup-and-use-usb-mic-hdmi-connection-including-measurement-techniques-and-how-to-interpret-graphs/150#post_22808127
Averaged:
What are your graph axis settings? I just did a quick measurement it only went as far as 200, even if I set the right limit to 300 or 400.
Also how do I post a graph in this tread?
Originally Posted by JChin  /t/1449924/simplified-rew-setup-and-use-usb-mic-hdmi-connection-including-measurement-techniques-and-how-to-interpret-graphs/180#post_22811449
When you say 200 do you mean 200 Hz on the x-axis? My graphs show full range, i.e. 20 Hz to 20 kHz. If you go back to my original post and click on a graph it will expand on your screen for easy reading.
For posting a graph (jpg), in the reply window you will find an icon on top for embedding images. Click on it, them look up the file in your computer and hit Submit. That's all. You can check how it will look like prior to sumbitting by clicking on Review.
Originally Posted by sdrucker  /t/1449924/simplified-rew-setup-and-use-usb-mic-hdmi-connection-including-measurement-techniques-and-how-to-interpret-graphs/180#post_22811194
Mostly because it is easier to read the analogue dial I think. You can just 'look and see' rather than having to 'read'. Like the difference between an analogue and digital watch. How many times do you see someone with an analogue watch glance at it and then, if you ask them the time, they have to look again?  First time, the position of the hands was all they needed to see to know the time. To convert it to a specific time (it is 27 minutes past six) they need to look again. On my 911. I have reorientated the rev counter so that the red line starts when the needle is pointing straight up on the dial - no need to read anything - the swiftest glance tells me I need to change up... :)
Some reviews I have read stated that the analog SPL is/was more accurate than the digital one.  However, when I checked the RS web site, only the digital one seems to be available anymore, BICBW.  The SKU for the new digital one is 3300099, and for the old digital one is 33-2055 (can't find this one either).
Originally Posted by mogorf  /t/1449924/simplified-rew-setup-and-use-usb-mic-hdmi-connection-including-measurement-techniques-and-how-to-interpret-graphs/150#post_22808212
It's another plug-n-play mic! LOL
Yes, except we do not have a calibration file for it... And it is hard to trust the linearity of the mic. input on notebook... at least I don't trust mine.
Originally Posted by IgorZep  /t/1449924/simplified-rew-setup-and-use-usb-mic-hdmi-connection-including-measurement-techniques-and-how-to-interpret-graphs/180#post_22811719
The only purpose of using the Audyssey mic with REW is to get acquianted with measuring techniques and REW itself until more people can get their UMIK-1 usb PNP mic. Worry not, nobody is going to make serious measurements with the Aud mic on this thread.
Audyssey off and Audyssey target overlayed:
So far, so good!
Here is a trick question, Feri:
Which of the following two response curves looks better?
The answer:  they are the same curves.  The difference, of course, is the smoothing and the vertical axis resolution.  How you set your graph parameters has significance in the value of what you are showing.
I think we should agree in this thread on certain standards for the graphs we publish.  My recommendations:
- Use 1/24 smooting for full-range graphs, and no smooting for graphs that focus on bass frequencies, say below 300Hz.
- Adjust vertical axis resolution so that the scale shows in 5 dB increments (I believe Jason made the same recommendation).
- Always include a full-range graph (20-20,000 Hz), as well as a graph that focuses on a problem range (e.g. bass frequencies 20-300 Hz).
Having said that, would you care to re-publish your averaged graph with 1/24 smoothing, rather than 1/3 smoothing?
would it be a problem if my soundcard's input doesn't work. but the computer onboard sound input works and i'm sending out audio signal to receiver via video card's hdmi output?
