541 - 560 of 30309 Posts
Originally Posted by mrfattbill  /t/1449924/simplified-rew-setup-and...how-to-interpret-graphs/500_100#post_22862836
So Larry, when are you going to come by and school me on the in's and out's of REW?
Bill
Hey Bill, as soon as I remember everything I forgot about REW
...OM is so easy but I want to go deeper into measuring.
If I can't get a flat or decent respond curve (by moving front speakers and/or sub), is it better to have more peaks than dips or more dips than peaks? Maybe my question is, whether its easier to handle peaks or easier to handle dips?
** Man of Leisure **
^ I suspect it depends on where the peaks and valleys are. Have you published a response curve? Some dips are caused by room modes, and cannot be easily addressed by room EQ. I would think peaks could be addressed by a combination of treatments and EQ. However, if you only have one sub, then there is a lot of evidence that shows adding additional subs goes a long way to smooth out the bass response.
Please post some measurements.
Now that the latest version of REW beta is compatible with OM, what "exactly" do I need to start taking measurements with a non-HDMI laptop and OM USB mic?  Latest beta version of REW + latest version of ASIO4ALL driver and I guess a splitter out of the laptop microphone jack and another Y cable for the mono portion of the Y coming out of the laptop going into the RCA jacks of my pre/pro input?  I suppose a single RCA cable would do if I only wanted to measure L+Sub, C+Sub or R+Sub but not a combination of any?  Sorry, I know this has been debated ad nauseum in the last 500 or so posts but I'm more of a picture guy and want to make sure I have everything hooked up correctly.
Originally Posted by jkasanic  /t/1449924/simplified-rew-setup-and...and-how-to-interpret-graphs/540#post_22864488
On the input side, you only need the OM microphone.
On the output side, you will use the stereo mini-jack on the laptop. You need a cable with a stereo mini-plug on one end, and dual RCA jacks on the other. REW will output a mono signal, so you need an RCA cable long enough to reach the AVR, and then a Y-cable to take the mono signal and connect it to the left and right AUX IN connections on the front of the AVR.
AFAIK, ASIO4ALL is only required if you are going to be using the HDMI connection to the AVR.
Originally Posted by AustinJerry  /t/1449924/simplified-rew-setup-and...how-to-interpret-graphs/500_100#post_22864517
So, by stereo mini-jack you mean the headphone output on the laptop (my laptop card only has a mic input and a headphone output).  So a cable like this with 3.5mm stereo to dual RCA (female in this case):
and then ideally a single to double male RCA cable (would a standard RCA work?).  The single to double RCA Y cable is what I'm struggling to find.  I guess I might need another adapter like this to plug the male side into the mono side of the previous adapter:
And then just a standard dual male RCA cable going from this adapter into the Aux inputs on the pre/pro?  If a single male RCA to dual male RCA cable exists that might simplify the connections but I couldn't find one doing a cursory online search.
^ The stereo mini-plug to RCA cable you show should work.  Then you would run a male RCA to male RCA cable to the AVR.  However, the second cable you show would not work, because you want a single FEMALE RCA to a dual MALE RCA, since the AVR has female RCA plugs.
Originally Posted by AustinJerry  /t/1449924/simplified-rew-setup-and...how-to-interpret-graphs/500_100#post_22864903
Jerry, first off, thanks for taking the time to respond to my questions. Your efforts here and in other threads I follow is definitely above and beyond!
I'm having issues replyiing to multiple posts using my iPad but the point of the two separate adapters above was to alleviate an issue you actually mentioned quite a few posts back to batpig regarding the mono output of REW and the fact that an additional Y adapter would be necessary going into the pre/pro otherwise you would have to keep switching the red mono cable between L and R channels and measuring them together would not be possible. I was unable to find a single male RCA (for the mono output of REW) to dual male RCA connectors going into the Aux input on the pre/pro. Therefore, I proposed the male to dual female adapter so that a standard RCA dual male cable could be used from this adapter into the Aux input. Make sense now? I'll edit this post with a link to the previous post for reference.
EDIT: Ok, here's the relevant discussion:
Originally Posted by batpig  /t/1449924/simplified-rew-setup-and...how-to-interpret-graphs/400_100#post_22848213
OK, so now we can route back to my original question which started this discussion:
Isn't the simple male>male 3.5mm to stereo RCA y-cable sufficient?
My understanding was that, with this cable, you plug into the left RCA AUX input to test the left front speaker, the right RCA AUX input to test the right front speaker, and BOTH of the AUX inputs (with PLII Cinema enabled) to test the center channel speaker. Is my understanding correct?
Originally Posted by AustinJerry  /t/1449924/simplified-rew-setup-and...how-to-interpret-graphs/400_100#post_22848687
Not quite. If you use the cable above, only the right channel, I.e. the red cable, will carry a signal (recall that REW is a mono signal). So, you would plug the red cable into the right channel input on the AVR to measure the right channel, and move the red cable to the left input on the AVR to test the left channel. However, to test left+right, you need to plug the red cable into a Y-cable, and feed both the left and right AVR channels simultaneously. Setting the AVR to PLII Cinema will combine the left and right signals and output to the center channel.
Does this clear it up?
Originally Posted by batpig  /t/1449924/simplified-rew-setup-and...how-to-interpret-graphs/400_100#post_22848705
Yes it does! Thank you!!
Silly me, the reason it wasn't clicking was that I assumed the mono signal output would be dual-mono, not just isolated to one of the RCAs. Cheers!
This comment in between the above discussion is what confused me but perhaps that's because I haven't used REW before:
Originally Posted by AV_mike  /t/1449924/simplified-rew-setup-and...how-to-interpret-graphs/400_100#post_22848511
Well I've been using the same cable for about a year, treating it as mono. REW input/output 1 is Left. With both RCA plugs connected (left & right), you use the Timing Ref Output to drive the "other" channel.
Regards, mike. (Sorry for lack of detail, sick in bed at present) - where's Jason when you need him?
Premium Member
I still can't understand after all this how you would make a calibration file for the sound card if you did not use the USB mic?
@ jkasanic,
A picture should clear it up:
Originally Posted by JapanDave  /t/1449924/simplified-rew-setup-and...and-how-to-interpret-graphs/540#post_22865177
I am not sure I understand your question.  Instructions for creating the soundcard calibration file are in the Guide (linked in my sig), Step 4, page 33.
Premium Member
Originally Posted by AustinJerry  /t/1449924/simplified-rew-setup-and...and-how-to-interpret-graphs/540#post_22865318
OK, so it is the same as before the HDMI output was added to REW. Thanks. Great guide BTW, I had not seen that yet.
Premium Member
After reading through your guide a bit more, is it safe to assume that if your PC does not support 8 channels, that you will not be able to play back all 8 channels in REW, just the left and right speakers?
Originally Posted by JapanDave  /t/1449924/simplified-rew-setup-and...and-how-to-interpret-graphs/540#post_22866220
That is correct. However, when analyzing room response, the important speakers to use in the measurements are the left, right, and center speakers, as well as the subs. You do not need 8-channel support to test these speakers.
Originally Posted by AustinJerry  /t/1449924/simplified-rew-setup-and...how-to-interpret-graphs/500_100#post_22865312
@ jkasanic,
Doh, male ends on 3.5mm adapter to a single female to two male Y adapter solves that issue with common cables! There's alway more than one way to skin a cat! Thanks!
Edit: is there any concern on cable lengths with this configuration (i.e. like not exceeding a 25ft extension with an Audyssey mic)?
Premium Member
Originally Posted by AustinJerry  /t/1449924/simplified-rew-setup-and...and-how-to-interpret-graphs/540#post_22866386
How do you test the center and sub if you only have stereo setup?
Originally Posted by JapanDave  /t/1449924/simplified-rew-setup-and...and-how-to-interpret-graphs/540#post_22866827
Is that a trick question?
Originally Posted by JChin  /t/1449924/simplified-rew-setup-and...and-how-to-interpret-graphs/540#post_22864393
Electronic EQ such as Audyssey XT32 can deal most effectively with peaks (they shouldn’t be too bad if you have optimised setup prior to calibrating). But electronic EQ can't do anything at all for true nulls - treatments and/or more subs is the solution there, especially, IME, the latter.  Also, electronic EQ such as Audyssey is wary of trying to correct large dips because attempting to do so can use enormous amounts of amp power, for little or no solution. This has the potential to damage speakers, hence the limitation. So it is always easier, when attempting to level out the FR, to cut the peaks down to approach the dips, and then boost the entire spectrum in volume to get back to the original level as much as possible. Again, this is limited in electronic EQ systems, so treating the room, optimising speaker placement and adding more subs is always a more satisfactory solution.
Premium Member
Originally Posted by JD in NJ  /t/1449924/simplified-rew-setup-and...and-how-to-interpret-graphs/540#post_22867026
On my receiver, no it is not. Especially if you want to measure the in room response with EQ applied.
But, lucky for me ,my laptop has 8 channels, so I don't have to worry now.
My sub measurement with the HDMI.
