Status
Not open for further replies.
1 - 2 of 2 Posts
Can you use a single coax for diplex operation of CATV and OTA HDTV? I ask because it doesn't look easy to run another coax from my wiring closet to my HT.
Steven
You cannot combine or diplex cable and OTA sources on the same coax without getting interference. Cable and OTA cover the same frequency range.
To do what you want - pull seperate cables for each and use an A/B switch ( or if your TV supports different coax inputs do it that way). Or use a VCR on the cable and pull the OTA to your OTA HDTV tuner.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/csb/facts/otard.html
1 - 2 of 2 Posts
Status
