Status
Not open for further replies.
1 - 5 of 5 Posts
I hooked the analog cable (Comcast NJ) straight into the slingbox and set it for analog cable. I then proceeded to scan and am only able to get channel 117 (weather channel). Thinking it was a cable issue I moved it from the cable modem to another spot with all new wire and a different splitter. Scan again and same thing. After manually searching all the channels I only get channel 5,6 and 117. Wondering if anybody else had the same problem with a known solution.
Hey krewl1, i know our guys just created a fix for this issue. I will drop them an email right now (i am travelling) and someone will be back online to help you shortly. hang tight...
thanks,
Blake
Krewl1
There may be a solution for the problem you are experiencing. Please contact Sling Media Technical Support at 1-877-GO-SLING (877-4675464). I know they can help.
Discussion Starter · #4 ·
Update...
I called tech support and surprisingly got hold of a live human being rather quickly. I was pleased at how nice and knowledgable both tech support people I spoke with were.Definitely a difference as to what I am used to. A quick firmware update and I was back in business watching all my channels.
I just want to thank the prompt responses in this forum and the quality tech support that made this a pleasurable experience. Hopefully this will continue as the company grows.
1 - 5 of 5 Posts
Status
