Need help with first build
We bought a house a few years ago that came with an unfinished walkup attic. Half of it didn't even have subfloor. After mulling over whether to convert our 2 car garage into a theater, or not, I've decided to use part of the attic as the theater.
Currently I'm finishing up the subfloor and trying to figure out how best to use the space. I've basically got a square box to work with. It's roughly 18x18 and the ceiling is 10 ft at the peak.
I've attached a few pics, but open to ideas and suggestions about how best to use this space as a home theater. In the pics you can see a beam running vertically in the middle from floor to ceiling, that will be where the screen wall will be.
Sound isolation is not really a major concern. This part of the attic is directly over my living room, and on the opposite end of the house from the bedrooms. If the theater is in use, then we'd all probably be together watching movies. I live at the end of a cul-de-sac, and my neighbors are at least an acre and a half away on both sides. So no concerns there.
What I'm really hoping to get some help with is how to set this space up to function as a theater. I've got some budget constraints as well, as we're finishing up other projects in and around the house at the same time. So, I can't go overboard on anything.
As far as equipment, the only thing I've settled on is the projector, BenQ w1070. Everything else from receiver to speakers and how and where they are positioned is open.
I've poured over lots of build threads with small theaters, attics, and bonus rooms and have gotten some great ideas.
But, I figured it would be best to get some input at this point before the electrical, framing, and walls are done.
Any and all ideas are welcomed!
Thanks in advance!
Thanks in advance!
