I have an EMP E10 sub that came with the tower speakers package when I purchased them. It's a small sub with only 100watt power. I actually like the sound from it for its size.
But there is a problem. The sub is front firing with a bottom port, ( pic ) and it's very light at only 27lb. Very often in movies during some low frequencies, the sub will "jump up" causing the entire thing to rattle. I don't really play loud at all btw and when I tried to "push down" the sub to the floor with my hands during these scenes, it sounded just fine with no distortion or anything. I think there simply isn't enough weight on the sub to pin itself down when the high air pressure shoots out from the port at the bottom. I do have wood floor, so I purchased a subdude. It doesn't solve the problem though because now the sub just jumps off the base of the subdude instead of the floor, causing a less severe rattle (as opposed to bouncing off the hard floor directly).
So what should I do to fix this situation? Is it okay to put something really heavy on top of the sub to hold it down? Will it change the sound somehow? I even thought about gluing its feet to the subdude lol.
