Noise and CFM are pretty much proportional. It's not really the fan but the air movement that makes the noise. Putting the fan away from the surface and sending the air through a baffle system allows the air to move but quiets it much like a car muffler does. I like to use a 12VDC computer fan powered by a variable power supply such as this:
http://www.radioshack.com/product.as...%5Fid=273-1667
I can adjust the power to meet the room noise floor.
