I believe that with the way WinISD models that if you've put in 240W as the input voltage and then had a 6 dB PEQ that it is modelling as though you have 960W at 30 Hz. You should be able to look at a Power graph in the software to confirm this. In that case you have little to worry about as the amplifier can't produce that amount of power.
