I need a small subwoofer (about 14 inch square or smaller). This is for my family room system, not my real home theater room. I realize a small subwoofer really isn't big enough for my room (2 story ceilings, about 15'x15', open to other rooms), but, for this room, I need something small. I'm also going to be limited in my placement of the subwoofer.
I listened to the Martin Logan Dynamo and the SuperCube III at Magnolia. I thought the Martin Logan sounded better, but it wasn't an ideal listening environment. I won't be able to hear the SVS SB12-Plus. I'm leaning towards the SVS based on reviews.
Do the people on this forum believe the SVS SB12-Plus would be the better subwoofer? Are there any small subwoofers that I also might consider?
Please don't recommend big subwoofers. I have an unused M&K MX-125 (dual 12 inch driver subwoofer) in a closet that I would use if I could go with something larger.
This will be used for home theater and music. More home theater, but I want something that sounds accurate. These will be used with Klipsch WB-14 front and rears and a WC-24 center channel (needed something small that could be wallmounted, and though I never really considered Klipsch for my home theater room, they actually sounded alot better than the small Definitive Technologies Mythos line and the Paradigm Cinema line to my ears).
The prices are: $699 for SB12-Plus, $650 slightly on sale for SuperCube III (though I know I could talk them down), and $499 on sale for the ML Dynamo. I'd prefer to stay less than $1000.
Any recommendations are appreciated.
