Well, cost is the only con I can come up with on Lutron.
You’ll spend 3X-4X more for Lutron. But the RF network is more reliable as is programming flexibility and choices of switches. .
If you don’t like the keypads, then Lutron is likely not for you. We find this the best feature as one button can do anything . For example, ‘Watch TV’ dims lights in the TV room, closes shades, turns down lights in adjacent areas (if done after sunset). Otherwise, just turns off beam lights near TV screen. One button and many different things done.
Lutron is upper end of cost. You won’t $12 thermostats, etc. You're going to spend $100 a switch and over $200 for the keypads. It does everything right... but you pay for it.
I like those keypads. The ’entertain’ and ‘Morning’ buttons each control the almost 40 switches at once on the main floor. the nice thing about Lutron keypads is you have to hardly touch anything to set lighting on a per room, per floor, or time of day setting. Lutron occupancy sensors negate the need to touch lights.
But really, they do far better at dimming LEDs. Lutron has recommended bulbs so you can get the most range out of your dimmers. They do the research. We used their recommended cans when building All good.
That said, given your needs Zwave may be your best bet.I like posting this for other readers who are looking at Lutron. It’s just an awesome bulletproof system.
One last cool thing... the integrated thermostat. No more ugly TStat on the wall.
