Hello all-
I need your advice.
The contractors are at the stage where they have double-drywalled the room and have built a soffit around the HVAC unit as well as a matching soffit on the opposite side wall.
I am wondering if this space within the inside of the soffit should be insulated or should it just be left hollow? As well, the soffit around the HVAC unit has room where I could add more insulation around two sides of it. It has already been wrapped once with insulation so I am not too sure if this is overkill.
If you think pictures may help, please let me know and I will post some tonight on this link.
Thank you.
I need your advice.
Thank you.
