Hi! I'm a happy owner of a Sony 1030. It's a later model that scans to 32 Khz, plus I have glass lenses mounted, so it's effectively a 1031.
Currently I'm running 960x540 and feed it via a HTPC with a Radeon-card and Powerstrip. I have a 15 meter shielded CAT-5, VGA to scart, and a simple electronic circuitry that does composite sync, so it's not done in software via Powerstrip.
I have two problems with the projector that I have learned to live with, but I would be very happy on any advice to get rid of them.
Problem 1:
I have slight ghosting on the whole image. If I for example look at the mouse pointer I can see about three vague "shadows" to the right of it, similar to this . It's not really noticeable in movies, but of course I would like to get rid of it. The projector has always been like this for the six years that I've owned it, regardless of what cable I have used. I don't think that it's the video cables fault, even though it's 15 meters long (I've had much shorter cables too). A shielded CAT-5 cable should not give ghosting, from what I've read.
The weird thing is that there is something with the Scart connector affecting the ghosting. If I fiddle with the scart contact of the video cable, I can get really severe ghosting. Sometimes it happens by itself, and then I have to gently push it around a little to find the spot with nearly no ghosting ("normal"). I didn't have this problem with my previous cable. That one had a slightly different gold plated scart contact. _Maybe_ it didn't happen because the scart pins where slightly longer, or something, but I can't really see any length difference. I think the problem lies with the female scart contact on the projector itself, though. Could there be some kind of oxidation, you think? Could I fix it, and could it potentially be the reason for the slight ghosting that I can't get rid off?
On the eboyztoys-page with the excellent 1031 guide, the author describes a similar ghosting problem that he solved by tightening the screw on one of the heat shields for the tubes. I have tried this before, though, and it didn't seem to help for me. Also, there is obviously something with the scart connector affecting the ghosting.
There does not seem to be any ghosting on the internal test pattern, which also suggests that there is ghosting on the actual video signal somewhere.
Problem 2
Before the projector has been really warmed up the picture now and then pops into a slightly "wider" mode. It stays like this and after a while goes back to normal. Usually it does this now and then, back and forth until (I guess) it is warmed up for real. Then it stays in the normal mode.
When it pops out and becomes too wide, there is also a slight analog noise in the picture that is most easily seen in white areas.
I don't know for sure when this started happening, but it might have been after I did a raster leveling adjustment and adjusted the width coils on the DA-board around two years ago. Could it be related to the width coils (this is my main suspicion)?
When the picture is too wide, if playing around in Powerstrip, the picture can for just a second snap back to normal, and then back to wide. Could it be related to scan frequencies, porch or something similar?
Has anyone experienced similar behaviour? Is there something that can be adjusted to fix this?
Any suggestions, on both problems are extremely welcome!
Thanks in advance!
Problem 1:
Problem 2
Thanks in advance!
