Status
Not open for further replies.
1 - 3 of 3 Posts
09/22 22:13:11 Notice: Scheduler Now Running
09/22 22:13:13 UPNP:: DVArchive has started listening to the network associated with 68.154.147.146
09/22 22:13:15 Notice: DVArchive Server Started
09/22 22:18:11 Notice: DVArchive Server Stopped
09/22 22:18:13 Notice: DVArchive Server Started
09/22 22:18:13 ERROR: Unable to open server socket -- Address already in use: JVM_Bind
09/22 22:18:13 ERROR: DVArchive cannot start a server on port 80, and will be unable to share video
09/22 22:28:33 ERROR: Unable to fetch details for DVR 65.154.147.147:80 -- Connection timed out: connect
09/22 22:29:40 ERROR: Unable to fetch details for DVR 68.154.147.147:80 -- Connection timed out: connect
09/22 22:30:51 ERROR: Unable to fetch details for DVR 68.154.147.147:80 -- Connection timed out: connect
I can not figure out how to connect via port 80..... I don't know what JVM_Bind is or where to disable it, or I would, please advise with any help. Thanks
Premium Member
Ten-second answer is that some other web server or something is using port 80 when DVA tries to start. The above threads will help you find the culprit.
(I'm curious why you are using an external BellSouth IP address.... this isn't a home PC, I guess? My point it: I hope you have a firewall between your DVA PC and the Internet! :) )
1 - 3 of 3 Posts
Status
