Somerset, WI: Antenna help
273 Views 2 Replies 3 Participants Last post by  Mr Tony
here is my tvfool info
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d5b947327ac673c
26 miles from most channels - two being high VHF, the rest UHF
Just moved into this house and would like to put an antenna in the attic. The signal will then be split to two TV's. Currently with rabbit ears on the main level of the house I generally get all the green channels (with minor tweaking required from day to day). The only other channel I'd like to get is 27, which of course is in the complete opposite direction of all the rest and a bit further!
First question is which antenna do people recommend? Second, what are the chances of getting 27 and all the others? I successfully did this at previous house (about 7 miles away from here) with antenna on the roof pointing to it. I would rather not do a roof mount at this location and I have no idea what type of antenna that was, I bought it at radio shack some 12 years ago I believe!
1 - 3 of 3 Posts
Please read the instructions at the top of the section. A location is required in the TITLE of ALL antenna help threads. See the sticky notes and my edit.
you might have a better chance at the translator on 47 for WPT (instead of 27) which is in River Falls. Its at least near the same direction as the Mpls stations
1 - 3 of 3 Posts
