Okay guys I need some help. I have started out deciding on the audio distribution in my house (Airplay vs. Sonos) and decided to go with Sonos.
I have 73" Mitsubish TV I purchased a while ago which is great except it only has coax audio output (and I'm not sure if it supports DD5.1 out).
I am realizing the limitations with SONOS and can't believe they decided not to include DTS or at least another input, but that's besides the point.
I need help in getting this to work. Here is the setup
-Plex server streams to Roku 3 plex client
-FIOS cable box
Those are the only two sources that I need. Roku 3 does NOT have an optical out, only HDMI.
I am okay with a 2.1 system for now as this is really for my parents and needs to be simple.
I am guess I will need some kind of switcher. But when I searched I haven't found anything clear cut that works with SONOS PLAYBAR. Since it has been out for a while, can someone make a recommendation on how to get this to work?
I don't want to have any delay or lag due to the switching and it would ideally be an automatic swticher (it's okay if it isn't they have a harmony remote that I could just program).
Really need some help here guys. Thanks so much
-FIOS cable box
