I recently bought a 10HT to use with my DVD player. Eventually, I will buy a HDTV receiver so I want to run the
cables for that now. Should I run an extra pair of component video cables with RCA ends? I'm thinking of getting the new Sony SAT-HD100. Does anyone have experience with this using the 10HT? I understand the SAT has outputs for component, S-video or VGA and I believe the component is the 1st choice for connection. Correct? One last question: the 10HT inputs have 5 connections marked : G/Y, B/Ca/Pb, R/Cr/Pr, SYNC/HD, VD. If the component connections go to the 1st 3, what are the last 2 used for?
Thanks, Tom
Thanks, Tom
