Status
Not open for further replies.
1 - 3 of 3 Posts
Hello,
I've some problems with my Sony 1031Q.
I can't get any image when I send composite signal with the 'NORMAL/SUPER MODE' set on 'NORMAL' position. But it works in 'SUPER' mode. With RGBs signals through the SCART input (European model), no problem at all.
Any ideas ?
Thanx,
Ghost.
Banned
Normally it should be set to normal but you have an export model so it may actually need it set to super. I would say it should be ok. Also you are using the SCART so you may be operating fine in this case. The SCART was for a computer hook up years ago.
1 - 3 of 3 Posts
Status
