Status
Not open for further replies.
1 - 3 of 3 Posts
Hi all,
I want to make this adapter by myself, then connect computer to this PJ.
VGA 9pin > VGA 25pin
I know the below pin only.
How about ground for RGB.
Anybody know how to make the adapter for
3 -> 3 // Blue
4 -> 2 // Green
5 -> 1 // Red
Many thanks for your help.
Desky:)
Are you certain that you have a 9 pin VGA ?
-- should be a 15 pin [ the size of the connector is the same as a 9 pin d-sub ] .
-- If you do have a 9 pin output on your PC then it will not work connected to the RGB2 input of the 1031Q [ The 9 pin is the older EGA/CGA style ] .
____________________________________________
Here are the PinOuts if you do indeed have a 15 pin VGA connection :
15 pin ____________ 25 pin
1 - red ____________ 6 - red
2 - green __________ 5 - green
3 - blue ___________ 4 - blue
6 - red ground _____ 15 - gnd.
7 - green gnd. _____ 16 - gnd.
8 - blue gnd. ______ 17 - gnd.
13 - H sync ________ 3 - sync \\_____ makes composite sync
14 - V sync ________ 3 - sync /
--- Best of Luck ,
---- Jason
Discussion Starter · #3 ·
Hi Jason
Many thanks for your advise.
Actually, I want to connect my PJ to HTPC (VGA 15pin).
I don't know which pin stand for.
Can I connect 1031 to HTPC ?
I want to DIY a cable for it.
In PJ, there are 3 input
1- compostive
2- 9 pin RGB
3- 25pin RGB
Please kindly advise how should I do.
Thank you.
Desky
1 - 3 of 3 Posts
Status
